replace felt roller on kn6030
  • digicor
    • Jul 2008
    • 1159
    Im assuming this means the lower fuser roller cleaning roller?
    How would i re set this message? Ive re set the fuser count, still there.
    or
    is this a felt roller somewhere else in the machine?
    Thanks for any info
  • JustManuals
    • Jan 2006
    • 9838
    Re: replace felt roller on kn6030
    Paul@justmanuals.com
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      no its the fuser webb on the top. 2 screws to remove the plastic housing 4 screws to remove the whole unit. dont reset nothing untill you check it has life left. Also check the little brown gear - this can cause the web to wrap round the hot roller.
      Incontinentia Buttocks
      • digicor
        • Jul 2008
        • 1159
        ok yes this is referring to the fuer web, it has life still on it,
        im going to change it out then re set 909 and ive been recommended to change the 194 count to 66 turns 3.
        ive also heard this saves the wear on the ufr.
        thanks for the info
          • 23010
          So far correct. Don't hesitate to lower the U194 values as needed. When the heat roller builds up with toner, I'll replace the heat roller, web, and cleaning roller, then lower the U194 values by 5 points (61/3, 56/3, ... ). The majority of my LTR and LGR machines are set ~45/3. Machines that do primarily LTR-R and LGL will need to be set considerably lower, closer to 35/3. Mostly it depends on fill rate.
          Keep in mind that 99/3 setting will make the web last 500K, 66/3 will last 2/3 of a PM cycle = 333K, and so on like that. At that 66/3 setting the web is advancing 3 turns every 66 image counts. At 45/3 you'll use two webs per 500K.
          Did I explain that clearly? =^..^=
          • Masterchief
            • Apr 2011
            • 280
            Clearly my old job could do with this info, they seem to replace webs 2 or 3 at a go before 500k
            Cheers
            Blackcat
            sigpic
