KM-c2520 showing PLEASE WAIT....... and stays there for long
  • dynsam
    • Apr 2011
    • 21
    hi all
    desperately need help.. KM c2520 showing PLEASE WAIT...... and stays there for long and copy function cannot be used and there is a red light indicator on the copy button..
    Need help. any assistance???
    • 23009
    Re: KM-c2520 showing PLEASE WAIT....... and stays there for long
    Is the DP-710 unplugged?
    Warning: Power must be off at the main switch on the right side, before re-connecting the accessory. Plugging in an accessory live is a great way to blow a board or corrupt the firmware.
    Or the original lift plate spring might be broken. I've seen both. =^..^=
    • dynsam
      • Apr 2011
      • 21
      Is the DP-710 unplugged?Warning: Power must be off at the main switch on the right side, before re-connecting the accessory. Plugging in an accessory live is a great way to blow a board or corrupt the firmware.Or the original lift plate spring might be broken. I've seen both. =^..^=
      Thanks blackcat,i'll try those options and see because it doesn't have a DP attached to it, only plattern cover
        • 23009
        Sorry. The only time I've seen the "Please Wait." it was related to the DP. =^..^=
        • kkendric
          • 301
          Does the display always stay in Please Wait? Does the Engine turn on the motors like it is warming up? I have two thoughts at the present, 1. HDD 2. Firmware. Not necessarily in that order. Good luck, let us know what fixes it.
