Waste Toner bottle 4500I
  • jockey
    • Aug 2008
    • 52
    Can you empty and reuse the waste toner bottle on Taskalfa 4500I? emptied one today and couldn't get the error message to go away.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Waste Toner bottle 4500I
    Yep, you have to clean the throat of the bottle. That's where the sensor sees the toner to detect that it's full.
    Empty & blow out with air.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • jockey
      • Aug 2008
      • 52
      Ok thanks, I cleaned but didn't use air
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        and make sure the diaphragm is glued on well
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          There are two little pockets in the neck...you can have an empty bottle and toner in those pockets and it won't work..just clean those out really good...
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • jockey
            • Aug 2008
            • 52
            Thanks guys, the canned air did the trick
              • 23009
              I've been trying very hard to convince my endusers not to empty these bottles. It seems that they prefer to dump the waste toner in tray #1, front door, floor, walls, ... everywhere, but it still doesn't work if the bottle is dirty. So I spend 1 hour vacuuming for a 10 second waste bottle change. =^..^=
