fs 1128 web password reset
  • trakyatoner
    • Jun 2025
    Hello
    i want reset web interface password because default admin00 not work, maybe anybody changed it.
    how i can do this .
    best regards.
    machine FS 1128 MFP
  • Eric1968
    • 2458
    Re: fs 1128 web password reset
    The only thing to do is to replace the main board.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      You need to send a prescribe file using ICLink32, it will reset to admin00 on all F4 machines....if you have program I can email you prescribe file
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • trakyatoner
        yes i know iclink 32 and i have got it. please send me prescribe code and i will try this. bilgi@trakyatoner.com or barisk79@hotmail.com
        • Venom
          • Nov 2009
          • 765
          Email sent.
          • Chillaholic
            • Oct 2010
            • 40
            You can use the ResetLan.exe for Kyocera.
            Just pick the printer/mfp as default printer and open the exe.
            It uses the printing queue, and sends a file.
            You need to add it over ip adress not usb.
            Has helped me often to reset all the admin passwords for many different Kyocera printers.
            • KYO_OEM
              • Aug 2011
              • 709
              • KYO_OEM
                • Aug 2011
                • 709
                • tmaged
                  Owner/Service Manager
                  • Oct 2008
                  • 1868
                  I've got an 1128 I need to reset the web password on. Prefer to not do 021. Anyone have the prescribe command for this ?
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • sammi
                    Hey Chillaholic !
                    Thank you very very much for that little proggi !My printer is the Kyocera fs-3900dn and NOW i can
                    use the COMMANDCENTER-html-soft .Greetings from Germany
                    • kraugans
                      Dear all,
                      I misconfigured the ip filter, so i am locked out to access the printer. No access via Command Center. As far as what I found out, there is no local access to the Command Center, which also means that resetting the whole printer is not possible via USB.
                      ResetLan.exe did not work for me. Or might I have done anything wrong?
                      It is a Kyocera 5350DN KX.
                      It would be great if anyone could help me or has an idea what to do!
                      Best,
                      Dennis
                      • XaR0uLiS
                        • Jul 2014
                        • 23
                        Originally posted by kraugans
                        Dear all,
                        Best,
                        Dennis
                        Hi Dennis,
                        you try this command
                        echo !R! KSUS "AUIO","RESET:0"; EXIT;>lpt1
                        Connect the printer via usb cable and use the "net use" command to capture the usb port to lpt1. Then send the command to the printer. There is a possibility to restore all the printer device settings with this command. So I suggest you to print Status Page, Network Status Page before the command.
                        I hope that you will solve your problem.
                        Harris
                        • XaR0uLiS
                          • Jul 2014
                          • 23
                          Originally posted by XaR0uLiS
                          Hi Dennis,
                          Harris
                          Important notification that I forgot to mention.
                          Switch the Security Level from High to Low before send the command.
                          • kraugans
                            Dear Harris, thank you very much. Problem got solved by the support, but it is good to know to have an alternative next time!
                            • Don N.
                              • Nov 2011
                              • 409
                              Can someone advise what procedure for admin00 reset on fs1135? I tried a prescribe command from another thread.
                              !R! KSUS "AUIO", "CUSTOM:Admin Password = 'admin00'";EXIT;
                              It seemed to work at the FTP command prompt, but still not taking admin00
