KM 5035 Fax Problem
  • kmtech
    • Sep 2008
    • 125
    KM 5035 Fax Problem
    I have a customer thats getting a U0115 Fax code. I looked in the book of knowledge it say { No message reception after transmission of an MCF signal.} Not real informative. Has anyone had this error and how they dealt with it.
    Bill
  • kkendric
    • 301
    Re: KM 5035 Fax Problem
    Does this happen on evert TX? or just to one number? You might want to perform an all clear for the Fax,U600 this will reset the Fax to factory defaults. Print phone list first.
    • kmtech
      • Sep 2008
      • 125
      No it just happens on and off, really dont have any other info and i will try the clear sim. thanks
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        have you turned off ECM?
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • 23010
          Most likely you've got a poor quality phone line. The transmitter completes the handshake, but fails during image transmission.
          Like kkendric, my question is: Same destination erroring out or randomly? If it's just one destination then that destination probably has a bad local phone line. If all randomly, the transmitter probably has the bad local phone line. =^..^=
