Cs-3050 Question
  • COPYME
    • Jul 2025
    Cs-3050 Question
    Has anyone had this situation? Machine will fax to every number, local or long distance but WILL NOT to any 800#
    Any ideas??
  • n25an
    • Jul 2008
    • 1030
    Re: Cs-3050 Question
    not machine... definitely phone line
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
      • 23009
      Agreed. Often business phone lines are set up to block certain three digit prefixes. The way to know for sure is to plug in a POTS handset and dial the number. See what result you get. =^..^=
      02 April 2008? I'm sure this problem is not his main concern anymore.
      • n25an
        • Jul 2008
        • 1030
        True but i figured... Someone else might have a similar issue...
        • ignacio.cortez
          • Jul 2010
          • 176
          Here is a thought, have you tried adding PAUSES to the dial string for 800 numbers, have you tried MANUAL dialing, if Manual Dialing works, it is possible you might need a couple of PAUSES
          • gneebore
            • Feb 2010
            • 555
            Any ideas??
            I have seen this before. The customer used a system like Skype or Vonage(can not remember which) as their phone system and fax line. The outgoing fax has a "blocked caller id" or "unknown caller id" that shows up on the receiving fax line. A lot of companies that have 800 fax lines will have any faxes received with either of those headers automaically blocked and will not answer them. Ask the customer what sort of phone system they use.
            Just as an added thought I have seen some of these that the error correction will block certain types of outgoing calls. You can go in and manually set the modem speed of the copier to a lower connect speed and see if that helpds too.
            • ignacio.cortez
              • Jul 2010
              • 176
              FYI, as far as I remember, this series only work with Analog Fax modems so VoIP services like Vonage and Skype should not work with the MFP
