Kyocera Taskalfa 820 shows jam
  • kyrenecopy
    • Apr 2012
    • 205
    [Error Code] Kyocera Taskalfa 820 shows jam
    Hey everyone, I have just switched jobs and I now work for a Kyocera dealer. Small problem is that I have never worked on a Kyocera before (32 years with Lanier/Ricoh/Riso/HP) and although I am not going to be a field tech in my new position, they are shorthanded right now so I am trying to fix a machine in the shop.
    Have a model 820 that shows a paper jam on the right side with a jam code of 00 on the control panel. All switches in transport area (up the right side) test good. The machine shows the following sensors as on in the sensor check screen: PE switches SW1,2,3,4; LIM Sw4, and Feed-E-1 Sw. Do not have access to the books yet, they haven't gotten that far with my new guy indoctranation so I am looking for help from the Forum. Thanks, Mark
    Testing 1-2-3, testing, testing. Is this thing on?
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Kyocera Taskalfa 820 shows jam
    j00 always means jam at power up. The actuator on one of those verticle transport switches is out of place
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
        • 23008
        Agreed. One of those verical path switches has probably gotten dislodged from it's mount, or the actuator is stuck. It's very common on Harrier and Harrier1 machines. =^..^=
        • kyrenecopy
          • Apr 2012
          • 205
          Problem solved. Found tray 4 paper feed unit not latched and plugged in all the way. Switch check screen said feed e-1 switch was on and limit sensor was off. After reseating the unit all sensors are normal and machine works great. thank you for all your help, hope this helps someone someday.
