Taskalfa 250ci black color problem
  • giannnnn
    • May 2025
    hello,
    I have a problem with a TASKalfa 250ci, it faded black print, while the other colors okay, I also changed the black drum but not much has changed. The small fonts print them, but the big ones do not. appeared a strange symbol on the display? what is it?
    p.s. I changed the development not black drum
  • rooster
    Re: Taskalfa 250ci black color problem
    Originally posted by giannnnn
    hello,
    [ATTACH=CONFIG]17901[/ATTACH]
    it okay.,
    first u check the drum refresh.
    second u check the laser unit.
    third u image is i can't see
    so pls show me detail image picture
    BR
    rooster
    • giannnnn
      thanks but how do I do these steps? I'm not a technical
      What is the symbol that is on the display?
      • rooster
        i wall see hold of the touch display panels.
        BR
        rooster
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          You replaced the developer unit and you aren't a technician? No way....But if you are a technician, print U89 and look at solid line, if solids are light is areas then the developer unit is faulty, look at the half tone line, if halftones are light in areas then the drum is faulty. Update the firmware to Ver 12a. Always shake the hell out of the developer units before installing to distribute the toner evenly.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • giannnnn
            1) I explain the problem: a technician came and changed development under warranty. But the problem remains. I print the posters, small fonts are good while the largest font is faded. the printer has 70,000. the warranty has expired. I would also like to know what is this symbol appear on the display
            2)i print a status report and the firmware version is 2h7_2f00.013.006 2012.01.06. is it updated?
            3) i've done the U89 and this is the result, is it normal?
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              it's the security level icon. Your security level is probably at it's lowest setting. Not a big issue. We have tons out there with that symbol.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
              • giannnnn
                ok thanks! and for the black? i can do anything?
                • Kidaver
                  Ghoulscout
                  • Apr 2011
                  • 912
                  Did the technician who came out to replace the developer go thru all the correct adjustments when he installed it?
                  • giannnnn
                    I do not know what is the right procedure, but nothing has changed after that changed the developer unit...
                    is the firmware version is 2h7_2f00.013.006 2012.01.06 updated?
                    • Kidaver
                      Ghoulscout
                      • Apr 2011
                      • 912
                      That does seem to be the latest firmware, but when he installed the developer did he go thru the AC Calibration and image adjustment procedure as well?
                      • giannnnn
                        I do not know but I do it? if you kindly tell me how to do?
                        • Venom
                          • Nov 2009
                          • 765
                          It is rare that an account doesn't have a service agreement...especially on a color box, the only thing a non tech can try are user adjustments, dev refresh, color refresh/gray adjust, color alignment.
                            • 22934
                            My recommendation is to call back your dealer and have them come back out to resolve the problem. It's a return call you should not be charged labor for their screw up. =^..^=
                            • JustManuals
                              • Jan 2006
                              • 9838
                              Paul@justmanuals.com
