Print Density on CS- 4500i
  • Dave10
    • Jul 2008
    • 197
    The Density on the new black and white machines seems really high to me. Very dark blacks and a lot of wasted toner. I can reduce copy density easily, but print density is a little more difficult. Does anyone know if you can change the FRPO values on the new machines. They are listed on the Service Status page, and referred to in the manual, but there is no information on how to change them. Anyone know how?
    • 23010
    Re: Print Density on CS- 4500i
    This command works on the FalconIII and Stratos machines (Early Wisecore), maybe it will work on the Gaia?
    !R! FRPO D4,2;EXIT;
    The digit in red specifies the setting. Three is standard, two and one lighter, four and five darker.
    It only affects print density. Experiment.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      To lighten copy density (print coverage by 30%) update firmware to Ver 4, then U140 image preference-copy set to 0, ok,stop,stop. To lighten printing density change in the print driver.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Dave10
        • Jul 2008
        • 197
        Thanks for the reply, Blackcat, but my problem is that I can't figure out how to send FRPO commands to the new 4500i. There is no method given in the manual, and I can't find it in the Command Center, either.
          • 23010
          The simplest way is to download a free utility called LPR Jar. It can be operated from your laptop or from a USB stick plugged into a networked computer.
          GCC File Send Utility
          Write your command to a .txt file (Textpad, or Notepad). Name and Save it.
          Open LPR Jar.
          Enter IP address of destination.
          Browse to command file.
          Send.
          • Dave10
            • Jul 2008
            • 197
            I'll try this. Thanks all.
            • noid
              • Nov 2012
              • 5
              Venom, have you done any testing on this? Or is this what the kyo rep suggested.
              • Venom
                • Nov 2009
                • 765
                I think Kyo rep suggested...still too early to know if machines won't spray toner everywhere over time
