Kyocera KM-3050- cf630
  • DaveA
    deamon1
    • 6
    [Error Code] Kyocera KM-3050- cf630
    I have a KM-3050 that is giving a CF630 code only when coming out from sleep mode, I believe that it indicates that the sleep mode mount/un-mount command is corrupted. So far I've re-formatted the HDD, done all re-initilize sims (s002, s020,s021,s022, s906) with no2 change. Sent the main pcb off to Hytec, it was returned with no problem found. Swapped out all dimms on main pcb, engine pcb & control panel pcb, with dimms from a machine with the same firmware. Also swapped engine pcb from a working KM-4050, but still have cf630 problem. Firmware level is: 2GR_2000.035.002. Am at wits end on this one, any ideas/suggestions?
    • 22999
    Re: Kyocera KM-3050- cf630
    The document I have recommends changing the HDD and re-loading firmware. I've never seen that one myself. =^..^=
    • habik
      • 2013
      We have chenged HDD and it went away.
      Also have a look at this as we had one customer where the power lead was obstruced many times by a guys feet and was semi-pulling the plug
      have a read maybe it help, although no direct solutions for both of the cases
      http://www.copytechnet.com/forums/ky...y-16-00-a.html
      http://www.copytechnet.com/forums/ky...ogether-2.html
      Firmwares HERE
