mita 3060 dirty copies
  • alan
    • Mar 2008
    • 40
    i had mita 3060 and always after just few use, copies came out dirty and much toner is accumulated beneath the drum and developing assy..imtired of cleaning it..is there any way i could run it back in its normal condition..
    • 30296
    toner
    are you using oem supplies?
    3060 old machine upgrade to new digital
    • 10871087
      • Jan 2005
      • 1062
      How many copier on your Drum, Blade, and Developer? Probably time to replace them.
      • alan
        • Mar 2008
        • 40
        176380 total copy count,if i try to change the developer will it solve the problem?drum and cleaning blade is new..what is the developer calibration?should i emptied first the toner box before i start developer calibration?or what?thanks!
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          hello tech...!
          dear friend tech... I have this probleme in the paste . listen the rate of developeur in down . but the level with toner is great. no you put some devel or you chenge it for the original . after their remplace the blade clining and you observet. ....allah maak.
          BEST TECHNICIAN . NICE PEOPLE .
          • oldcopyguy
            Do a devloper change
            • 10871087
              • Jan 2005
              • 1062
              Don't know, but that is the next logical thing.
              • alan
                • Mar 2008
                • 40
                mita 3060
                thanks for the replies,ill do the dev.cal.nxt i guess it will work out well..with all the suggestions i got from you..thanks..
                • vaclav borc
                  • Jan 2008
                  • 75
                  I had this problem with MITA DC 3055 . Toner was transferd on drum surface,
                  than cleaned by drum cleaning blade into toner used tank.Machine added toner continualy into developer and so on.
                  Only changing drum solved this problem.
                  • ITCHYFINGER
                    change the developer, run sim 30, i think that was the tds setup. we have no more of these units out. they always had large amounts of toner built up under the dev unit. just get into the habit of taking the drum and dev unit out and cleaning it up.
                    • 10871087
                      • Jan 2005
                      • 1062
                      The fix for the old 3055 was a new toner sensor and a fresh bottle of developer, or a sledge hammer to beat the crap out of that crappy customer killing box.
                      • ibs boy
                        • May 2006
                        • 11
                        Hi guys:
                        Try cleaning all the end blocks for the transfer/seperation unit. That unit will cause a lot of other problems also.
                        • Absurd
                          Just a brick in the wall
                          • Oct 2007
                          • 118
                          Hate to go against everyone on this but the old mita DC-3060's and DC-4090 came in two series. The first off the line had horrible issues with running very dirty and needed to have the image unit completely cleaned every 30-40k. The only thing I ever found to help the problem was to replace the eprom sets with the same eprom level that came out on the second batch of machines. Some people would change some of the dv settings but this never did much in my experience. If you cant change the eprom set you either need to get used to cleaning that rail under the drum and under the dv section every 30k or so or you can upgrade that 12 year old piece of $%#&.
                          Southern Duplicating of Mississippi
                          PSN: DrAbsurd (if you know you know)
                          "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
                          • arriva1
                            • Apr 2007
                            • 66
                            I had one of these on contract a while ago and the recycled toner would constantly get backed up and rock hard had to clean constantly. recycling toner sounds good and works well on some machines, but im my opinion the deposal works better. They just try to do to much with these things an almost always causes head aches.
                            • kyocera10
                              • Sep 2011
                              • 13
                              Re: mita 3060 dirty copies
                              replace the cleaning brush, or better yet replace the machine heheheh
