TA300ci - no cyan and weird blue marks on prints and copies (see sample)!
  • Estico
    • Jun 2012
    • 21
    [Electrical] TA300ci - no cyan and weird blue marks on prints and copies (see sample)!
    just replaced Cyan Drum, Dev and Transfer Belt - same result! Any idea? Thanks.
  • kyrenecopy
    • Apr 2012
    • 205
    Re: TA300ci - no cyan and weird blue marks on prints and copies (see sample)!
    What was the original call for? And am I missing something here, I see cyan on the test sheet you attached?
    Testing 1-2-3, testing, testing. Is this thing on?
    • Tonerkiller
      • Oct 2012
      • 668
      The color cleaning motor is not turning. Turn machine off, take the back cover off, turn on machine and all motors should spin. Replace the ones that are not turning.
      • Estico
        • Jun 2012
        • 21
        the original call was for blue dots - replaced cyan drum then got no cyan on color belt U089 - only the blue marks... After that we tried new cyan drum, dev and transfer belt - no result.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • madas
            • Aug 2008
            • 313
            I have seen a similar fault on other models as a main charge issue.
            madas
              • 23008
              madas
              I'm with madas on this one. If the interval is 38.9mm it's the primary charge roller arcing.
              Did you replace just the cyan drum, or the cyan drum unit assembly (which includes the primary charge unit)? New parts or used? =^..^=
              • madas
                • Aug 2008
                • 313
                Here's a couple of samples I have of this fault.
                madas
                • dyodyo
                  • 28
                  If you already replaced Drum Unit, Dev. Unit and Transfer Belt and the result is the same as you said then check the values of U100 (Adjust DC2)? Maybe somebody mess around with the settings.
                  • Tonerkiller
                    • Oct 2012
                    • 668
                    It still looks to me like the cyan drum is not cleaned. The waste toner builds up on top of the drum unit and the tran belt rubbs on that toner and leaves marks on all prints.
                    • Estico
                      • Jun 2012
                      • 21
                      yep - i replaced the cyan drum unit assembly, cyan dev and transfer belt. Also swapped out with Yellow drum (which includes the main charger) - same result.
                      • Estico
                        • Jun 2012
                        • 21
                        • ccwilliams3
                          • Jun 2009
                          • 22
                          What about the color cleaning motor?
                          • Estico
                            • Jun 2012
                            • 21
                            We fixed it today - the board interface where the color drums and devs connects was causing the faulty ground issue (blue marks on prints). Thanks everyone!
                              • 23008
                              Thanks for sharing. =^..^=
