Copystar Cs220(Taskalpha 220) with c2000 error
  • axyun
    • Aug 2007
    • 1323
    I understand this is a main drive motor error which could be bad motor or forced error from resistance in fuser or developer unit. I had seen possible door switch problem or possibly erratic voltage fluctuation due to main charger arcing. Please correct me and add any input you can give me related to this code as I have very minimal experience on this series. Your help is very much appreciated and i will post results of our efforts. Frank/ActionPhotocopy
    • 23008
    Re: Copystar Cs220(Taskalpha 220) with c2000 error
    I've only got a couple in the field, and haven't had to service them often. There for a while I had CS-1650's and CS-2550's that I saw regularly. They were low volume and we had a lot of trouble with arcing to the drum (pinholes), and the ozone buildup on the mirrors. But no drive problems. I'd follow through on checking the various torque loads on the main drive motor. =^..^=
    • axyun
      • Aug 2007
      • 1323
      Thanks David.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • axyun
          • Aug 2007
          • 1323
          Thanks Paul. I have the SM + PL.
