kyocera fs 3140 Occasional white faxing
  • samuele
    • Aug 2025
    A client of mine pointed out to me that occasionally faxes sent are white. I have already update firmware.
    • 23010
    Re: kyocera fs 3140 Occasional white faxing
    The most common cause is the enduser placing the originals wrong side up. Applies to all manufacturers, all models with fax function. =^..^=
    • samuele
      Thank you but it is not... sorry
      • RCR
        • 11
        Hi Samuele,
        Ask to end user if place the original on the contact glass,
        in this case probably the user close the DP when the ISU scan the original.
        I remeber that in this case the 3140 produce a partial white copy or fax.
