KM 3050 firmware
  • cfltech
    • Aug 2009
    • 13
    KM 3050 firmware
    I need to upgrade the firmware on this machine, does anyone have the firmware?
  • HenryT2
    • 962
    Re: KM 3050 firmware
    YES .....
    Kyocera does ( you must be a certified tech to get the firmware ) .... or Manuals4 you ......
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • JustManuals
      • Jan 2006
      • 9838
      Yes, I have it, email me if interested at Paul@justmanuals.com. Like everything else in this world, it isn't free but it's cost won't break the bank either.
      • RollingROARANDA
        • Nov 2012
        • 72
        You will also need a Compact Flash card.. Are you sure the FW update is completely necessary??
        That dam machine is so old, it may be time to sell them a new TaskALFA 3050ci !! (fanfare) lol
        OK, but seriously, you got to download it from Kyocera, maybe you got a buddy on kdaconnect, eh? After that, if you got a similar model machine, like a KM 2050 or something laying around, power it off , plug in the CF card, power it on, to format the card the way the machine likes it, if that makes any sense.. Then load the FW onto the root of the freshly formatted CF card, and off you go..
        • kkendric
          • 301
          For the CS/KM-3050, 4050 & 5050 copier you can use a CF-Card or a USB Memory stick to update the Firmware. These devices may be formatted in your computer, it is not necessary to format them in a machine. You should be fine with formatting them to FAT or FAT 32. The Firmware file is arounf 94.7 Mb so you will need at least a 100 Mb CF-card. I have used up to a 1Gb usb memory stick as well. You must expand the files on your computer then you can copy to either device and follow the standard procedures for firmware installation.
          • JustManuals
            • Jan 2006
            • 9838
            I couldn't find the frimware on the Kyocera site. :/
              • 23009
              It's version 2.45a.
              Look under Legacy MFP Black & White. =^..^=
              • JustManuals
                • Jan 2006
                • 9838
                Still can't find it.
                  • 23009
                  Sent you a PM and email. I think you'll find it now. =^..^=
                  • JustManuals
                    • Jan 2006
                    • 9838
                    I don' think so, No Frimware there for the 4050 or the 5050.
                    Paul
                    • kkendric
                      • 301
                      Just sent you an email, The KM/CS 3050 is still with thw most current models at KDAconnect, but the 4050 5050 use the same firmware.
                      • JustManuals
                        • Jan 2006
                        • 9838
                        I wonder why I couldn't find it. I looked and looked. Anyway, I have it now. Thank you for your input. I'll boost your rep.
                        Paul
