KM-2050
  • TEC DOG
    • Sep 2011
    • 113
    KM-2050
    HI to all
    First print from this copier is always good but all next are light.Machine have 93K.Toner is OK.Customer is far, so i need some suggestions.Im tend to drum issue,moist paper,drum contacts,transfer roller,firmware,power supply...?
  • Mike Watson
    • Oct 2012
    • 13
    Re: KM-2050
    You could also try the dev unit clutch, have had very similar faults on other konica minoltas. Cheers
    • Cartaos
      • Feb 2010
      • 6
      Re: KM-2050
      Check the spring and the contact of the transfer roller.
        • 22952
        Re: KM-2050
        Have you done a thorough cleaning of the optics and slit glass? These machines have known issues with ozone buildup on the mirror surfaces. Clean with 99% alcohol. I think you'll be pleasantly surprised. =^..^=
        • TEC DOG
          • Sep 2011
          • 113
          Re: KM-2050
          Thank guys.And Blackcat, If copier have dirty optics,can you explain flawless first print?
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            Re: KM-2050
            I've seen toner buildup on the heat roller in the fuser which often leads to fumes up onto the optics...but if you've gone thru the machine looking at stuff I'm sure you would have noticed a problem like this
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • just a tech
              • Jan 2007
              • 332
              Re: KM-2050
              BlackCat hit the nail on the head with that model being historically bad about hazing on the mirrors.. The lightness I've always seen from that family of machines was mostly in the middle area of the optical mirrors.. So the middle of the optics was more covered in haze more than the two ends were..
              First of all.. I suppose we need to rule out some things so we can all be thinkin about solutions to the same problem..
              -- Cut your machine in half by copying and then printing something from the unit.. If it is good on 1st print but light on rest of the prints, then you know it is within the engine of the machine and not in the top half of the machine.. So that would rule out your optical components..
              -- If it good on all prints, but light on all copies after the first one, then you know you are dealing with something in the optical section..
              I'm guessing you will be having the problem during printing & copying which means something within the engine..
              If so.. Are you using OEM toner or Compatible toner..? I have had light image issues before that were resolved with the use of OEM toner..
              Also... What type of location / environment is the machine operating in..?
              Good Luck..
              Just a Tech
              • JustManuals
                • Jan 2006
                • 9838
                Re: KM-2050
                Paul@justmanuals.com
                • TEC DOG
                  • Sep 2011
                  • 113
                  Re: KM-2050
                  Hi guys.Thanks to all for your help.The is no end of human stupidity.Customer find on the web a solution to fix problem with clearing data in service mode.I set back developer and transfer values.Thanks again.
                  Happy new year.
                  • Eric1968
                    • 2458
                    Re: KM-2050
                    Happy new year.
                    Customers messing around in the Service Mode, a recepi for more trouble...
                      • 22952
                      Re: KM-2050
                      Happy new year.
                      Pure genius ... and billable. It's a good thing this machine is monocomponent. =^..^=
                      • just a tech
                        • Jan 2007
                        • 332
                        Re: KM-2050
                        Another fine example of why a lot of guys on here refuse to give out service manuals to just anyone who asks for it.. Somewhere down the line, it will usually cause trouble for the certified technician that has to go decipher the screwup and try to fix the issues caused by the unknowing person..
                        Glad ya got it goin bud..
                        Just a Tech
