km c 2535e touch screen not responding
  • kyogenius
    • Jul 2012
    • 136
    [Misc] km c 2535e touch screen not responding
    Seems like recently nearly 5 of my machines in the field got the touch screen frozen,at times when i strip the LED assembly and clean it ,it works sometimes i gotta change it. Any idea the cause or remedy besides replacement.thanks guys
    failure is not an option !
  • kkendric
    • 301
    Re: km c 2535e touch screen not responding
    There are multiple fixes for this situation 1. replace the tablet PCB, 2. Clean crud from around display and op panel 3. Iron flex cable at connection on tablet PCB, this revives the connection sometimes. 4. There have been some firmware updates regarding responsiveness of the tablet PCB.
    The best fix is to replace the Tablet PCB, usually about $54.00 from Kyocera. This problem is caused by a degredation of the conductive adhesive used on the Tablet PCB as Kyocera calls the touch screen.
      • 23010
      kkendric is right, assuming this is a KM-C2525E. There is no C2535E. =^..^=
      • kyogenius
        • Jul 2012
        • 136
        thanks blackcat its a typing error its kmc 2525e,ddnt notice it.To kkendric thanks so much for the info
