Document Processor, DP-750
  • Jfell
    [Misc] Document Processor, DP-750
    I have a DP-750 on a Kyocera 300ci. The MFP is current on FW. The DP itself is having an issue raising all the way to feed through the jobs. You can apply light pressure on the top cover and the tray will lift and feed. You can then do the same job and it will lift all the way and feed properly. It does this randomly, but again apply slight pressure it continues to raise and work fine. Give me some fellow techs?
    • 23008
    Re: Document Processor, DP-750
    Three possibilities:
    1) a paper clip or small scrap of paper has dropped into the photointerrupter that monitors the movement of the lift plate
    2) the spring that provides the lift may be broken (but it would not feed at all)
    3) the post that the top cover latches to may be broken.
    What jam codes?
    • Geo
      • 662
      Check the "holder LF" Thats the plastic frame that the feed pulley is attached to. The top front center clip/latch brakes causing the assembly to come down too far . This causes the flag on the holder not to properly activate the pressure sensor.
      Cheers
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Tonerkiller
          • Oct 2012
          • 668
          Cheers
          Geo has it pegged
