scan system F, memory
  • Dennis Lay
    KM-1650 scan system F. I need to add 526M memory. Where do I put it?
  • Zackuth
    • Aug 2009
    • 448
    Re: scan system F, memory
    That's a dangerous way to phrase that question with this group.
    If at first you don't succeed, redefine success
    • Zackuth
      • Aug 2009
      • 448
      After looking at the various guides for the 1650, I don't see anywhere that the scan system F can have memory added. And the max amount of memory I found that can be added is only 256 MB.
      I did find this blurb in Tech Bulletin 1, but could not find any installation instructions.Recommended Micro Drive: Hitachi or IBM, 340MB, 512MB or 1GB.
      • kkendric
        • 301
        Image memory max 2X128 Mb, Printer memory 64Mb built in 64 + 256Mb = 320 MB and the addition of a micro drive.. Memory is installed on the Main and Printer Boards.
          • 23010
          The Hitachi Microdrive is a miniature hard drive that acts exactly like a compact flash card, and inserts into the CF slot. =^..^=
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Copy memory max. 1x 128MB
            print memory max. 1x 256MB
            fax memory max. 1x 32MB
