KM8030 desk feed mylar
  • Toner Boy
    • Aug 2007
    • 366
    Anybody know the part number for this item? Mylar in front of separation roller, Deck 2 (left side tandem feed). Can't locate in PG.separation_mylar_infeed.jpg
    Maybe not a spared part.
  • Zackuth
    • Aug 2009
    • 448
    Re: KM8030 desk feed mylar
    Part # 302KP10540--Film feed left
    If at first you don't succeed, redefine success
    • Toner Boy
      • Aug 2007
      • 366
      Thanks a lot, much appreciated.
        • 23010
        The CS-820 manual has part numbers for several items that never got part numbers in the CS-8030 manual. Not all are identical, but many are. =^..^=
        • just a tech
          • Jan 2007
          • 332
          Also, just to let ya know.. The left side mylar and right side mylar are 2 different part #'s.. They look pretty close to same but are different numbers..
          Just a Tech
          • Toner Boy
            • Aug 2007
            • 366
            well...since I'll be needing it and don't have the CS parts guide...got the part number for the right side mylar (Deck1)?
            Also, this drum is pushing 1mil. I assume it will require cleaning at some point to lengthen its life, got any tips or part numbers for cleaning powder etc? Been ages since I cleaned an ASi drum.
            • just a tech
              • Jan 2007
              • 332
              The part# that Zackuth gave you is different from what I have in mine, but it is same part..
              My resource lists :
              Right Side Deck #1 -- 302FB09410 -- Film Feed C
              Left Side Deck #2 -- 302FB09360 -- Film Feed B
              As far as the drums go..
              Kyocera rates the drums at 3.6 million copies (CS-6030) and 4.8 million copies (CS-8030), so ya still got a while to go.. LOL..
              IF you need to clean the drum, they recommend using a dry clean cloth..
              I have some of these in the field that have over 4 million copies on them and still using the original drum.. The recommended maint. cycle on them is 500k.. If you perform a full pm on em at those intervals, ya shouldn't have too much of a problem.. Within the maint. kits is included a "cleaning unit ass'y".. If maint. kits are done regularly, there shouldn't much need in having to clean or dust the drums.. At least I haven't had to with mine..
              BTW -- Be careful when handling drum.. Last I checked, they were around 1,004.00 from Kyocera..
              Hope it helps,
              Just a Tech
              • Toner Boy
                • Aug 2007
                • 366
                Good info, thanks. This one's been running well 'cept for having to replace the developer unit (would starve itself and not add toner for some reason) and the motor/fuser drive unit issue. Might have to get some more out in the field if I can find good deals on toner and quicker parts source than PR. Thanks all for your help.
                • Zackuth
                  • Aug 2009
                  • 448
                  My resource lists :
                  Hope it helps,
                  Just a Tech
                  Just a Tech, the numbers from the 6030/8030 cross to the new numbers given in the 620/820 part list. The mylars have been completely redesigned and now do not look alike. The new work just fine in the old style machines.
                  As far as drums go, I never messed with one unless there was a problem.
                  • just a tech
                    • Jan 2007
                    • 332
                    Yup.
