kyocera km-c3232 cassette out of order (tray 4)
  • AlcanMan
    • Aug 2025
    Getting out of order error in cassette tray four have swapped cassette closed switch, lifter motor and pick up assy. Still present any help appreciated in advance........possible firmware problem or lower controller board? Tray will not lift.
  • KYO_OEM
    • Aug 2011
    • 721
    Re: kyocera km-c3232 cassette out of order (tray 4)
    U906?
    Still out of order?
    Eventlog, which C-Calls or Jam codes ?
    KYO_OEM
      • 23009
      It should be a C-1040. It's not uncommon to have a lift motor take out the driver circuit on the engine PWB. If the U906 partial reset doesn't help and you're still not getting the ground signal to operate the lift motor, I'd get that engine PWB ordered. =^..^=
      • AlcanMan
        Originally posted by KYO_OEM
        U906?
        Still out of order?
        KYO_OEM
        Thanks KYO_OEM the u906 fixed my problem. Much appreciated.
