Why don't Kyo drums last a lifetime?
  • Fer
    • Nov 2009
    • 267
    Hello, i am a Canon tech and from Canon i know two kinds of drums. Ceramic and opc, opc normaly lasts 60-80k on an A3 machine, while the Ceramics will stay there a whole lifetime, up to 3 Million copies.
    Now i learned that all Kyocera printers use Ceramic drums, but they only last 300k. Can somebody please explain how this is possible.
  • Eric1968
    • 2458
    Re: Why don't Kyo drums last a lifetime?
    The ceramic drums have the advantage that they last longer than other drums. You can also clean them with water. For example if a customer is using labels and the glue of the labels has covered the drum, you can always use water and a soft cloth to clean them, no probem. But they are also sensible to scratches and dirt. These drums do certainly not last for 3 Million prints. 300k for the Taskalfa 250ci/300ci/400ci/500ci is a normal amount. There are machines that have drums that last longer, but I haven't seen drums that last 3 millions prints. I haven't got experience with the High Volume Kyocera's, but the normal office machines use drum that last 300k-600k.
      • 23009
      The CS-8030 and CS-820 can both get 3M prints if ... it's run at high volume and the primary charge is kept in good condition (not arcing).
      This same if applies to all Kyoceras. =^..^=
      • Chameleon
        • Nov 2011
        • 200
        I've wondered the same thing. I'm used to seeing the Canon drums go 3-7 million depending on the charge units, then I see a drum for a Kyo FS-3900 that can't make it to 300k. The DK-320 looks like a smaller but identical version of the Canon drum. The drum even looks great but can't make a good print. My theory is it has to be the aftermarket toner, or maybe Canon uses a thicker coating of ASi (Amorphous Silicon). After seeing some downright awful looking drums put out great copys on Canon's, I just can't shake the feeling I'm throwing away good drums everytime I replace them on the Kyoceras.
        The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
        • Fer
          • Nov 2009
          • 267
          Let me put it another way.
          Can u refurbish an old Kyocera for cheaps, by polishing the old drum, empty and clean the developer. Clean or replace the corona wire, replace the fuserROLLER?
          • DWise
            • 895
            On the desktop Kyoceras, you can clean the Main Charge Unit (on top of drum unit). Can also vacuum generic toner from developer and add OEM, if needed. Never tried polishing a defective drum. If there's a scratch, toss it and get another one.
            Do for one what you wished you could do for everyone. - Andy Stanley
            • Jules Winfield
              • Jul 2009
              • 821
              Just like every other industry nowadays, there's no money in making products that last forever...
              But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
              • MR Bill
                • 532
                What is the cost of the Canon drum compaired to the Kyocera drum. I am guessing that there is more coating on the canon drums?? So they last longer? Just a guess.
                • Fer
                  • Nov 2009
                  • 267
                  I guess the price of the drum is roughly half of a new machine. More expensive than a Kyocera drum.
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    doesnt matter if the drum never reaches its target life as the warranty is so good is free.
                    Incontinentia Buttocks
                    • sweet.persona
                      Engineer
                      • Nov 2009
                      • 414
                      i heard that can make selenieum at the surface for drum to live long life that's true!
                      A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
                      DAMENE ABDEL AZIZ
                      DJELFA
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        if you're looking to refurbish the fs series printers, leave the drum alone but buy and replace charge rollers., cleaning them won't last even if it makes them look new
                        • Fer
                          • Nov 2009
                          • 267
                          Charge rollers? Didn;t they use scorotron charging?
                            • 23009
                            Corona wire charging, actually. No scorotron or charger roller. For Canon and Kyocera. =^..^=
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              Charge Roller
