Kyocers KM3035 laser head
  • jimrd
    I am looking for a good used laser head. Can anyone help me out?
    • 30300
    laser
    are u getting code or CQ problem?
    • jimrd
      C4200 code
      Getting a C4200 code
        • 30300
        CODES
        Yep You Need A Laser
        We Had Had Some With Cq Issues Like Light On On Side That We Opened Unit And Cleaned Mirrors
        • denisr
          c4200 Error
          Hi, Ia m new to Kyocera.
          Having C4200 Error Msg, once I clean the Head What should I do
          DO I need to reset machine
          thanks
          • 10871087
            • Jan 2005
            • 1062
            thanks
            Replace the laser if cleaning doesn't fix the code.
            • Mark B
              • Jul 2006
              • 153
              The machine needs a new charge wire and clean grid 99% of the time you get a 4200 code
              • denisr
                thnks Mark,
                I shall try it and let u know.
                By the way when I finish doing this cleaninfg. Do I need to reset the copier
                thanks
                denis
                • jasonofx
                  Service Tech
                  • Nov 2006
                  • 64
                  Seconding this. Try a new charger unit in the drum and reset the machine (10871087 906). I have discovered the charger was the problem 2 times after replacing the costly LSU.
                  • kyoceradude
                    The Great Gazoo
                    • Aug 2006
                    • 442
                    I'll third this with a twist. Sometimes the drum is damaged from the charger asnd you will need to replace the drum...
                    My mission here on Earth is to help all you Dum-Dums!
                    • geisener
                      also check the connectors for the transfere roller and make sure they are straight and making good contact . if they are arching it to can cause a laser code
