Creasing
  • luis8832
    • Dec 2008
    • 250
    [Misc] Creasing
    I am working on Copystar 3050ci, i first went to the account because they were experiencing creasing on copies and prints. Per the troubleshooting guide there is a new modified guide. I ordered it and installed it. The customer just called back with the same issue. Any ideas out there would be greatly appreciated.
  • JohnKetteridge
    Re: Creasing
    In most of the cases i have seen. The creasing is caused by moisture in the paper.
    You should check maintenance mode (10871087) and sim 327. These are the tray heaters and should be put to on.
    Give the machine 24 hours to heat up and dispers of any moisture in the paper.
    Can you show an example of the creasing?
      • 23009
      Re: Creasing
      Check the heat belt bushing. I've seen them ground to dust on the drive end. It may also be accompanied by gear noise and C6600 intermittently. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Re: Creasing
        Paul@justmanuals.com
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Re: Creasing
          remove the saw tooth and guide< the saw teeth are too long and contacting paper
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • luis8832
            • Dec 2008
            • 250
            Re: Creasing
            Figured out what was causing the creasing, on the convey unit there are 4 white pulleys. The 2 towards the rear of the unit were not moving. There are springs that hold them down. I cut the springs down 2 loops, reinstalled and tested. The creasing is gone!
            • Zackuth
              • Aug 2009
              • 448
              Re: Creasing
              I've got a machine doing the same thing and the two rear guides are pushed out further than the front two. It was late in the day on a Friday and did not want to try and race the clock, plus I wasn't exactly sure how to get in there. Cut the spring down, I'll give that a try.
              If at first you don't succeed, redefine success
              • Zackuth
                • Aug 2009
                • 448
                Re: Creasing
                Luis, that was the solution. Thanks!!!
                • Tonerkiller
                  • Oct 2012
                  • 668
                  Re: Creasing
                  did the creasing start after a new fuser was installed?
                  • Zackuth
                    • Aug 2009
                    • 448
                    Re: Creasing
                    I don't know if we have replaced the fuser in that machine or not (probably we have), but I don't think that these roller would be affected by a new fuser because of the distance between the two, but I won't say it's not the reason.
                    • toddanderson
                      • Dec 2005
                      • 236
                      Re: Creasing
                      On all the machines the springs are different on the rear side for the white rollers, you would think they should be the same ?
                      • Zackuth
                        • Aug 2009
                        • 448
                        Re: Creasing
                        Perhaps. I did not take the front ones off and compare sizes, but it might be something to look into.
                        • luis8832
                          • Dec 2008
                          • 250
                          Re: Creasing
                          Happy i could help out. I have gotten alot of help from many of the techs in this forum and website.
                          • BeardyBloke
                            • Mar 2009
                            • 7
                            Re: Creasing
                            seems to be a common problem, as the rear springs are too strong for the holder and the shaft pops out - KM have modified the part - 302K908250 (holder middle pulley)
                            • Tonerkiller
                              • Oct 2012
                              • 668
                              Re: Creasing
                              That was what I was thinking also
