Black copy FS-C8025MFP
  • kaborwen
    • Feb 2010
    • 146
    [Misc] Black copy FS-C8025MFP
    I get a problem with FS-C8025MFP. All copy by DP or glass coming out totaly black. The printer status and all prints are ok. I need a help please. Thanks.
  • Tonerkiller
    • Oct 2012
    • 665
    Re: Black copy FS-C8025MFP
    It is not transfer, I would say lazer also
    • kaborwen
      • Feb 2010
      • 146
      I don't think so because printing is ok.
      • blackandwhite
        • Aug 2012
        • 67
        same kind of problem in FS6030-6025 also.... for that ,engine/main pwb replacement required....
        but for Fs8025 ...really first time i am hearing this problem.....
        • Eric1968
          • 2458
          x2 for the Main PWB. There was a bulletin out for this problem (bad transistor on the Main PWB).
            • 22934
            x3 main PWB. You'll have to run sim U004 to restore serial number. The re-enter network data and addressbook.
            • kaborwen
              • Feb 2010
              • 146
              I replace MAIN PWB and it's ok. I use U004 and U917 for serials number writing, user data backup and restore.
              Thanks all.
              • kronos
                • Feb 2013
                • 4
                common problem on the 8025 /6030 ....unfortunately if you run latest firmware the machine will lock up displaying 3200 ERROR...so till you get the new replacement main board don't run firmware else machine can only be used as doorstop till board replaced ...
                run u004 to write serial
                and hopefully you backed up with u917 before removing board
                Regards the Titan
