F186
  • FINGERS123
    • Nov 2012
    • 33
    [Error Code] F186
    I have a brand new taskalfa 6500i that keeps getting a F186 code i have already replaced main, engine, ribbon cable, and hard drives and this code still persist. It says it's a communication error and have checked and changed everything the manual has said to. Any suggestions.
  • kkendric
    • 301
    Re: F186
    Service Bulletin C128-2LH-0010
    Measure for the white void on image/F182/F186 error (High voltage contact failure between the right cover and the transfer belt unit)
    • melbarr
      Re: F186
      Would you happen to have a opy of that Bulletin? I can't seem to find it...
      • Kyo fan
        • Dec 2013
        • 368
        Re: F186
        Just got this code on one of my FS-6525MFP. Firmware upgrade didn't help. The machine just prints 1 blank page and F186 pops.
        Any solid ideas to save me some time before i start butchering it?
          • 22997
          Re: F186
          What happens if you disconnect the network cable, then boot up?
          What happens when you connect to your laptop via crossover cable?
          This is the description I have: Print Unit: DVU_PRT_SYSERR_F226_ERROR (Video data flushing error).
          Two things I get from that:
          Possible bad image memory
          Possible corrupt print data, or non-print data reaching the print card.
          Of course, you updated the firmware. =^..^=
          • kyocera.team
            • Aug 2010
            • 126
            Re: F186
            F18x its means theres an error at the video control section try to check the harness between main and engine PCB (YC3main YC46 and 50 engine,U 24 format HDD full,U21, engine or main PCB need to be change,check it one by one and hope it help.
            • Kyo fan
              • Dec 2013
              • 368
              Re: F186
              Thx for tips guys.
              For blackcat: It doesn't matter if network cable is connected or not, same issue. You get a single blank page and than F186 if you try to print anything (status page, event log, etc). I've found the bulletin kkendric mentioned for TA 6500i: 2LH-008.pdf though i don't think it could be applied in my case on FS-6525MFP.
              Didn't have much time today to deal with this, will deal with it tomorrow and update how it went.
              • Kyo fan
                • Dec 2013
                • 368
                Re: F186
                Faulty main pwb in my case. Thx for tips.
