Black copy with TA-520i
  • kaborwen
    • Feb 2010
    • 146
    Hi all,
    I have black copy and prints with TA-520i. The problem is not all time. It's random problem. I check main charge and all HV contacts. I need a solution please. Thx.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Black copy with TA-520i
    Paul@justmanuals.com
      • 23009
      It's going to be something related to primary charge. How about replacing the primary charge unit, and if it returns HVT? =^..^=
      • kaborwen
        • Feb 2010
        • 146
        I didn't replace them, but I sow something wrong on the Power suply board. the big capacitor does not value it should. Do you think it's can make this problem? I will change it.
        • 20gaugeO/U
          • 557
          Check the grounding tabs to the transfer roller on the left side door. If they are bent you can get strange black bands sometimes covering the entire page.
          • kaborwen
            • Feb 2010
            • 146
            Ok I will check and let you know.
            THx
            • To@ster
              unplug cleaning motor from corona charger, remove grid by removing one screw, take off small metalic shaped wire, most of the time making bad contact with charger unit. Put back grid and leave unpluged cleaning motor.
              • kaborwen
                • Feb 2010
                • 146
                I replace main charge unit and it's working fine. thx all.
                  • 23009
                  You're welcome.
                  Thanks for posting back the results. =^..^=
                  • MFPTech
                    • 486
                    I was wondering if this problem came back after you replaced the MC Corona.
                    A colleague of mine had exactly the same issue when he did a PM. Then he put the old MC Corona back and the problem went away.
                    The problem just came back and the call got assigned to me. Before heading out there thought to check the forum.
                    Thanks!
                    • MFPTech
                      • 486
                      Update; replaced the MC Corona and the problem got fixed. Was able to recreate the problem with the old MC Corona. The problem hasn't come back.
                      • kaborwen
                        • Feb 2010
                        • 146
                        It was not the corona problem cause printing was OK only copy get black. In my case it's was the scanner PWB.
