Re: Kyrocera KM4050 with df730 finisher (stapler only) won't work properly - help?
Thanks, you know I do respect your opinion and your experience. I thank you for your help too. and for taking the time to respond.
If I can use an analogy, using a memory clear is like using a sledge hammer to sink brads. The brads go in. The brads drive in one stroke. And it leaves a huge depression in the wood everywhere you strike.
There's a better way than the sledge hammer approach. Use the right tool for the job.
1) Start by finding out what code you are addressing: E000 Error Log. How will you know what to fix if you don't know the error code?
2) Fix that thing.
3) Reset only the error in U906.
I would hope that you can restore function, without de-tuning every adjustment on the machine. If you care what the prints/copies look like, save memory clear functions for catastrophic events, not minor events like resetting a code. It can take several hours to perform all the adjustments required to get perfect image quality back, and some of these adjustments require special test sheets that I do not carry, like shading adjustment.
****stepping down off soap box**** =^..^=Leave a comment:
You are wrong, do not ask for advice if you are not going to use it. Blackcat is probably the most knowledgable on this site and his advice should be respected.Leave a comment:
Your "soft reset" is a memory clear, and not too smart. I don't know where this idea comes from that a "factory reset" actually fixes something. It only throws out the settings that took a lot of work for someone to input. If you were to take a close look at your prints now, you'll find that the print centering, print image registration, print voids, scan centering, scan registration, scan voids, scan magnification mainscan and subscan, DP centering, DP registration, DP magnification all now out of whack.
I'm sure the next tech with a manual will be thanking you for your assistance.
Maybe I am wrong or understood it wrong but U021 seemed to be the answer. Perhaps U906 would have been a better Choice. And I will check the copies/prints and scans more closely but so far they seem to be fine.
Blackcat is right about U906. If there's a problem with a finisher, document processor, paper trays, etc, you can always do U906, reboot the machine and see if the error is solved. If the problem is related to the finisher, the machine disables the finisher and switches to the standard output tray. U906 resets the error.Leave a comment:
Thanks again.Leave a comment:
Print off an E000 Error log to determine the current error.
To reset the error perform an U906 Partial Reset. That should solve your problem.
I just installed a km4050 with a df730 finisher. The machine sort of recognizes the finisher but, it doesn't. If I print a status report it says a 1000-finisher is installed. (df730 is 1000 sheet finisher). Now here is the issue. I can go to copy mode, select staple and the status displays
"output tray has changed, >>> finisher tray then "cannot use this function"
If I go to system menu, common settings, output tray, copy/custombox, ... the finisher tray option is grayed out like it doesn't see it. Only top tray is useable.
Why won't the finisher work? what am I missing?
-NormTags: None
