KM-8030 wavy paper
  • Master Sparkee
    • May 2010
    • 31
    KM-8030 wavy paper
    I have a problem with a KM-8030. When making multiple prints (10 or more) I don't see it, but when making short runs, it shows up. Starting about 4 inches from the tail end of copies, the paper is wavy. Repeats about every 1 1/2 inches to the end of the paper. So far I have changed the fuser and transfer. I find no binding in the gears or belts assy. The fuser drive assembly looks great and there isn't a spec of gear dust anywhere. The problem is seen from all cassettes. I doubt it is a paper issue or it seems to me that the wavy mess would be more random. The paper path is spotless.
    Has anyone seen this problem before? If so can you make any suggestions? Thanks in advance. Hoping for advice before I start throwing parts at it
    Sorry, no. Techs don't carry toner.
  • Zackuth
    • Aug 2009
    • 448
    Re: KM-8030 wavy paper
    You might want to look at the fuser exit section. I had one that was solved by changing the solenoid that activates the top gate.
    If at first you don't succeed, redefine success
    • Tonerkiller
      • Oct 2012
      • 665
      Run the copies out face up. If they look fine, then the problem is in the turnover section.
        • 22934
        How about this:
        Wavy prints & copies, ledger size only. Paper scraps jammed in machine eject roller (fig 29-13), all the way to the rear. Remove paper scraps from the machine's eject rollers.
