Firmware update doesnt seem to do anything!
  • entity1
    • Dec 2012
    • 10
    Morning all.
    I have a Taskalfa 400 ci that I have doen a firmware update on after installing a new transfer belt in order to clear a C2700 error. The printer appears to load the Firmware update ok, however when I rebbot the printer nothing appears to have changed as I still get the C2700 error any help suggestion would be more than welcome. (apart from buying a manual that always seems to pop up whenever I put something on this board).
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Firmware update doesnt seem to do anything!
    That would be a color release motor error...which is in the transfer belt...and can only be replaced by installing a transfer belt...what I would do is order another transfer belt and replace it again....and send that bad one that they sent you for the machine...I have had this happen before....put in a brand new belt and get this error....
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • JustManuals
      • Jan 2006
      • 9838
      So you want the expertise of the experts on this board to give you advice but you're too cheap to buy a manual. Sad.
      • entity1
        • Dec 2012
        • 10
        I have purchased another brand new transfer belt and replaced it in the machine. However this doesnt clear the error. Is there something else that I need to do as I update the firmware it all apears to update fine, however when I attemp to turn the power button off on the control button prior to removal of the power leads the power button appears not to function. I there anything that I need to do from in service mode!
        • entity1
          • Dec 2012
          • 10
          I have already brought a manual!
          • ss12
            • 289
            http://www.copytechnet.com/forums/sh...ad.php?t=57391
            Try this thread
            • entity1
              • Dec 2012
              • 10
              SS12.
              Thanks for the the link to the thread. I will try those out when I next visit the machine.
              • entity1
                • Dec 2012
                • 10
                • entity1
                  • Dec 2012
                  • 10
                  checked this again this mroning and sure enough a pin had become displaced (printer side). SS12 many thanks for your time and help truly appreciated along with all the other who took the time to read and post suggestions.
