toner spillage in TA 4500/5500 i machines
  • blackandwhite
    • Aug 2012
    • 67
    [CQ] toner spillage in TA 4500/5500 i machines
    hai....
    lot of toner spilling from rear side of the drum unit ...see the pictures....most of the machines having this problem.....drum unit cleaned so many times...still problem remains... any modification is available for this problem....or drum unit to be replaced?
    because of this toner spillage ,heat roller also damaged....
    any solution guys.....
  • dikyo
    • Apr 2011
    • 45
    Re: toner spillage in TA 4500/5500 i machines
    Hi, This steps could be done: clean the whole machine and place a seal-set kit.(instructions included) Replace the dev. unit. Upgrade firmware (04.00.0030)
    • leroyal
      Expert on The Obsolete
      • Sep 2007
      • 156
      A DC-4086 for the new millennium.
      I know what I know better than anyone else knows what I know.
      • copylogic
        • Oct 2012
        • 15
        Hi replace the dev unit, 2LH93034
        Some of the original dev units shipped within the machine were assembled less accuratley than others.
        www.copylogic.co.uk
        www.photocopiersupplier.co.uk
        • blackandwhite
          • Aug 2012
          • 67
          shall i get the part number for seal-set kit.......
          • dikyo
            • Apr 2011
            • 45
            Partnummer seal-set
            Partnummer seal-kit:302lh94341
            Grtz.
            Dikyo
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              the seal kits are a joke...instead of fixing the toner scattering issue, they have you install sponges and mylars to try and stop toner from spraying everywhere though the machine. I agree, new dev unit is the fix.
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
