Kyocera km5050
  • shrum1340
    • Jun 2008
    • 44
    Kyocera km5050
    I have a km5050 with accordian jamming at eject unit. Replaced both fixing unit and eject unit. Will work somtimes for a few copies then start jamming agan accordian at the eject guide. Was thinking it might be something like a guide on the door that meshes with the fuser when door is shut. Anyone had this problem in the past?
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Re: Kyocera km5050
    Look at the sep claw unit mounted on the door....the should be a 1/8" projection on the guide front and rear. If you installed a used eject assy, look for toner build-up
    I know what I know better than anyone else knows what I know.
    • blsquires
      • Nov 2008
      • 342
      Re: Kyocera km5050
      ive had that problem ,single copies ok more than one it did what you have got .it turned out to be the registration clutch.
        • 23010
        Re: Kyocera km5050
        This is it right here: (302GR25371)
        It also helps to talk to the customer about slamming the door, or more specifically not slamming the door. I had one of these calls last week. The cause was the endstop in tray #1 being set to A4-R when LTR-R is loaded. They shattered all the pressure roller claws and the exit guide as a result of the slamming.
        I recommend that they close the inner section first, then the outer. No slamming necessary ('cause it's billable). =^..^=
        • shrum1340
          • Jun 2008
          • 44
          Re: Kyocera km5050
          Thanks for the reply's. I was was leaning toward the pickoff assembly on the door or the white lever above it that activates a guides.
