fuser for kyocera fsc5030n
  • burbug2
    how do you replace the fuser for the 5030n color printer i am not getting the correct pressure on one side. do you remove the back cover?
  • Necrocannibal
    • May 2008
    • 212
    Just open the back door that allows access to remove jams and pop it off, it just has two pegs on either side it hinges on. Then remove the two silver screws and it will pull straight out, very simple.
