CF File Not Found - KM 4035
  • djfenti
    • Nov 2012
    • 20
    When trying to upgrade firmware on a KM-4035, I get a "CF File Not Found". Any advice on how to get around this would be greatly appreciated. Thanks in advance!
  • kkendric
    • 301
    Re: CF File Not Found - KM 4035
    The smaller the CF card the better, I have had luck using 8Mb up to 512Mb. Format in computer using Fat. Expand firmware file then cut and paste or copy to root of Cf. I have not had luck with CF cards over 512 Mb. You may have to try several different cards to get one to work. This may sound silly, but it works. I am not a field tech I am a circuit board tech and have repaired hundreds of these boards for the KM/CS 3035, 4035 and 5035. Remember this series is around ten years old and technology has progressed quite a lot in thes years. Ten years ago a 1Gb CF card was a large CF card. Good Luck
      • 23010
      Like he said ...
      Two major points:
      1) smallest possible CF card
      2) format the card on the MFP
      3) Unzip the firmware to a folder on your PC, copy the unzipped firmware to the root of the CF card.
      OK ... three points. =^..^=
      • kkendric
        • 301
        I do not think that you can format the CF card on the 3035, 4035 or 5035,for the main system firmware, but if they have a print system you need to format the Cf card in the print system to update the print system firmware.
