3500i scanning to email limit
  • T911
    • Jun 2007
    • 628
    9 or 10 pages are OK. If I try to scan a batch of 30 or 40 no good 3101 error. I changed the size limit to 0 unlimited in cmd ctr advanced SMTP. I also increased the scan time but no luck. What am I missing. Thx
  • ss12
    • 289
    You may be limited by the exchange account settings.Have you tried changing the dpi to a lower resolution?
      • 23009
      Re: 3500i scanning to email limit
      Agreed. You may be reaching the limit exchange will allow for attachments. How large of a file can you send?
      Ways that you can reduce file size include:
      1) reduce resolution (dpi)
      2) scan in black & white. Color files are 10x larger.
      3) select Text document type
      4) Email files are slightly smaller than SMB or FTP scans of the same document all other settings identical. Not sure why ... ?
      • T911
        • Jun 2007
        • 628
        agreed. You may be reaching the limit exchange will allow for attachments. How large of a file can you send?
        3) select text document type
        4) email files are slightly smaller than smb or ftp scans of the same document all other settings identical. Not sure why ... ?
        all good thanks much. I reduced the dpi to 2x1 and it was set up in color so i changed it to b&w.
