FS-3140 please wait messge
  • madas
    • Aug 2008
    • 313
    Hi, just wondered if anyone has had this error.
    Turn m/c off comes ready and all functions work, put into sleep mode then power from sleep mode it has the meassage "please wait" no whiring of toner adding nothing like that just sits there. but if you try to do a copy it just beeps,
    all other buttons will change to thier respective screen just cannot copy and or use the scan side of things. updated f/w. optics where fithy as in a wharehouse type enviroment so I cleaned them thinking it is having trouble reading the reference plate???? no different disconnected/reconnected a few cables and still the same.
    to get it working you need to power off then on and it will work until next sleep mode. weird one.
    madas
  • HenryT2
    • 962
    Re: FS-3140 please wait messge
    Can you turn the SLEEP mode off on this model ?
    If not ... try putting the SLEEP timer at the max ....
    Good Luck ...
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • madas
        • Aug 2008
        • 313
        Good Luck ...
        Hi, HenryT2
        I dont think it can be turned off and the mx is 240 mins which it is set at now.
        Worked on many of these type of mfp's but not seen this one before not without some sort of noise/error code.
        they can still print while this message is on screen but just cant use anthing that requires pressing the start button.
        will post fix.
        madas
        • madas
          • Aug 2008
          • 313
          Thanks Paul but have access to manuals
          cheers
          Madas
            • 23006
            Whenever this has come up on other Kyoceras, it has required a firmware fix. Maybe you can try downgrading to a bug-free version? =^..^=
            • aborad
              • Aug 2011
              • 61
              I have latest firmware if you need..ashish@avtechnology.co.in
              • RCR
                • 11
                Hi madas,
                The problem is the ISU Pwb ( Image scan unit ),
                I had the same problem, in this is case it's necessary replace the ISU.
                • madas
                  • Aug 2008
                  • 313
                  Thanks for your ideas, I will try and post the fix
                  Cheers
                  madas
                  • madas
                    • Aug 2008
                    • 313
                    Originally posted by RCR
                    Hi madas,
                    Cheers RCA this fixed the issue
                    madas
