KM5050 error code CFB31. Not in manual
  • selig67
    • May 2008
    • 158
    Machine will not boot up, just goes to blue screen and displays CFB31 error. There is nothing in the service manual or on the website about this.
  • TA_Tech
    • 76
    Not Much but will point you in the right direction
    According to my info this is a communication problem between the Panel PCB (don't know which one) and the controller PCB (I suppose this the main PCB - Difficult to say because i have the info in German and have to translate). Symptoms are as you said a blue, or black screen. Possible source of fault is Panel PCB, controller PCB, or connection cable
    • selig67
      • May 2008
      • 158
      what I did
      I just replace the main PWB and hard drive from a different machine.. it now boots up but goes into a CFB30 error code.. but at least I got rid of the blue screen!!! is it possible that this error is because the machine I borrowed the board from is a 5050?
      • TA_Tech
        • 76
        CFB30 related to CFB31
        My info Gives the same symptoms for this code as for CFB31. but instead of communication error between panel PCB and controller PCB, says it is only comm. error with controller PCB.
        • JSC
          Gimp
          • Dec 2006
          • 618
          First thing to try is to change the Dimms there is a set under the ops panel, and a one in the main board, you MUST change them as a pair. If thats no good swap the ops panel complete but remember to swap the dimms in the panel so you keep the same pair on the machine.
          Good Luck.
          Let us know how you get on............
          The gene pool could use a little chlorine.
          • selig67
            • May 2008
            • 158
            that was it!
            I had taken the board out of the 5050 to see if that was the problem and I still got the error. I brought the op panel over from the 5050 and the error went away. So it was the fact that I didnt have all the original dimms together.
            THANKS!!!
              • 23010
              The firmware was at different levels. All you needed to do was reload firmware to the latest v. 2.05A. The date that shows on the Configuration Report is 1/28/08.
              • selig67
                • May 2008
                • 158
                cool!!
                thanks for the firmware advice.. I always use firmware as a repair tool!
                • aodtech
                  • 194
                  I had a 3050 that triggered a CFB31 code only when it the network cable was plugged in. Disconnect it, reboot the machine, everything works. Plug it back in, reboot, CFB31. Turns out the other end of the network cable was plugged into a switch which had another network cable with BOTH ENDS plugged into the switch creating a loop. Connected everything the right way, code went away.
                  • TA ITT FRANCE
                    • Jun 2008
                    • 6
                    List of CF CODE
                    Hello,
                    Here is a list of codes for KM 5050/4050/3050
                    PS : The list is on the Technical Bulletin 23 (TB23)
                      • 23010
                      Hey, that's a great list. This is probably the first complete description of CFxxx codes I've ever seen. Thank a lot, TA ITT. It's very much appreciated. =^..^=
                      • techman
                        • Dec 2007
                        • 49
                        its a enginer code according to tch support they told me to try upgrading the firmware. make sure you copy the bit maps with the files or the error code will keep comming back.
                        • BrazilBoy
                          Same issue
                          Heres my issue I have a 3050 that was self rebooting..I did the dimms, firmware, and memory stick per Tech Support...Now I am getting a CFB31 code now..
                          The copier locks up sometimes at startup sometimes when scanning and lately it reboots by itself without anyone near it...Very odd and tech support is at a loss on what to do..
                          I was thinking about setting it on fire that would fix it ounce and for all..This has been an ongoing issue for 2 months now...
                          Thanks Roberto
                            • 23010
                            You've got two expensive options: Main PWB or Op Panel. The odds are even, it could be either one equally. You choose. =^..^=
                            • BrazilBoy
                              Thats what I was thinking too...I will try Hytec and see if they got some refurbs for me..Thanks Cat for the quick reply and help...
                              Later Roberto
