Regular Firmware vs Turbo Firmware?
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Just a couple of questions about firmware updates for newer Kyoceras.
    Turbo only updates things that have changed while the regular firmware updates everything, correct?
    When should I use the turbo version or when I can't I use the turbo version might be a better question? Like if I have a machine that has the version 3 firmware but wasn't updated to 4. Can I use the turbo of version 5 or should I use the regular version?
    Thanks!
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Re: Regular Firmware vs Turbo Firmware?
    Actually, I'm having trouble downloading the regular version. I'm not sure how this all works exactly.
    Edit: I figured out how to extract the files now but the files are the same size. What's the difference between them?
    O.o
    • Tonerkiller
      • Oct 2012
      • 668
      I always use the regular firmware.
      • JR2ALTA
        • Feb 2010
        • 2033
        There's no difference except it wont erase and rewrite whats still current so it's faster.
        But usually if you're trying to troubleshoot you want to totally rewrite it anyway to cover your bases
        • 20gaugeO/U
          • 557
          Tech support also likes to hear that you are using the regular firmware vs turbo. Regular is all I carry.
          • User Name
            Awesome Sauce
            • Nov 2009
            • 405
            Is it normal when you download the regular firmware for the file name to end in _exe? I can't do anything with it until I change it to .exe but once I do change it works like I figure it should.
            Just glancing over the files they look identical except for one additional file in the turbo version entitled ES_SKIP. Would this be all it takes for the machine to know to skip over the drivers that don't need updated?
            O.o
            • Zackuth
              • Aug 2009
              • 448
              The first time I tried turbo was on a set up and I used turbo for one machine and ther regular for a second. I think the turbo was 4-5 minutes faster. After that I just used the regular.
              If at first you don't succeed, redefine success
              • Jules Winfield
                • Jul 2009
                • 821
                I'm pretty sure the "turbo" firmware is more of a Placebo than anything else...
                But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                  • 23009
                  I'll have to agree with the others. The only situation Turbo might be useful is if you're upgrading (1) version, and you have no issues to address.
                  If you're trying to fix anything, or are upgrading 2 or more versions, use the Regular. I have enough firmware to carry without doubling the amount. I only use and carry regular. =^..^=
                  • Jules Winfield
                    • Jul 2009
                    • 821
                    I hear what you're saying, but if there are no issues to address then updating firmware is not only a waste of time but may cause issues that weren't there before. Just look at all the Saturn updates....
                    • zaza
                      MECANOGRAPHE
                      • Mar 2008
                      • 1095
                      always we search a new version of frimware ....asked our friend paul about this subject ...!!!
                      BEST TECHNICIAN . NICE PEOPLE .
                      • Jules Winfield
                        • Jul 2009
                        • 821
                        Ahh, there he is. What's up, big pimpin'?
                        What's a firmware discussion without Zaza?
                        • zaza
                          MECANOGRAPHE
                          • Mar 2008
                          • 1095
                          dude jules l am Technician Supervisor Field in maintenance for copiers and printers machine since 1997 l started working in this specialty ..l think so you know that in your past history ....also always we discovered more frimware since long time ..in past and in future ...don't worried about that ....be easy .
                            • 23009
                            Clear and concise, as usual. =^..^=
                            • DWise
                              • 895
                              I could not have said that better myself...
                              Do for one what you wished you could do for everyone. - Andy Stanley
