KM4050 cassette problem
  • Rolandito
    • Aug 2007
    • 87
    I have a message with paper cassette 1 "error ocurred''
    I tryed U906 and U020.. and error persist..
    I changed the Lift motor and same problem..
    I drawed out the cassette I can see the lift motor is turning slowly and continuosly
    What do you think???
    • 22999
    Re: KM4050 cassette problem
    I think ... it would be a good idea to know what the actual error is. Print a U000 Error Log. Once you know what the error is, you can look up the number and address the actual problem, not just shotgun the whole machine. =^..^=
    • Has Been
      • Nov 2012
      • 48
      Bad Engine Board
      • JSC
        Gimp
        • Dec 2006
        • 618
        Yep, Engine board. Done quite a few of these on the km3050-5050 range.
        The gene pool could use a little chlorine.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          don't replace engine board without a new lift motor installed
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • Tonerkiller
            • Oct 2012
            • 668
            Seen it also, replace the eng board and motor at same time. That new motor that you put in is probable blown now.
