c4035e - hdd format - won't print now - control panel buttons dead (display good)
+ More Options
Posts
  • copierpro
    • Apr 2007
    • 270
    Rescheduled the delivery. Don't know what happened but yesterday machine working perfect - firmware sys 2JD_3000.003.005 engine 2JD_1000.009.001 - did a format hdd and now it won't print - print button on control panel just flashes when I send a print job.
    I wasn't even aware there was a problem as yet. Had a sticky button on control panel. Removed it disassembled cleaned reassembled (I know the three connectors are solidly connected to the PCBs in the control panel) - now the display is the only thing that works. The start button illuminates, the power button top right, of course, the printer light flashes when I send a print job that won't output prints since I formatted the HDD
    What a clusterfawk. Should have left well enough alone as copier was working perfectly until I formatted hdd and removed control panel.
    I know I was careful with control panel - did nothing incorrectly as far as disassembly/assembly.
    Any suggestions appreciated. We got a sale on this trade-in and want it gone plus the sales rep has a customer waiting and he's becoming gum on my shoe.
    Thanks in advance!
  • kyrenecopy
    • Apr 2012
    • 205
    Re: c4035e - hdd format - won't print now - control panel buttons dead (display good)
    WHy did you format the HDD? Why did you remove the Control panel? sounds like you need to reflash the firmware
    Testing 1-2-3, testing, testing. Is this thing on?
    • copierpro
      • Apr 2007
      • 270
      The number 1 on panel was sticking some crap down in there so I took control panel off. Button works fine now though, as written, the control buttons are dead.
      Did the format to erase previous customers' docs for security purposes for their benefit.
      First, did the HDD format. Did not even check operation after doing that, then took care of #1 button issue (did not even touch right side board area and buttons there just the numeric keypad board)
      • copierpro
        • Apr 2007
        • 270
        don't know much about the KM line we are Xerox (mostly) here.
        • kyrenecopy
          • Apr 2012
          • 205
          Hmmmm, ok, I would pull control panel apart again and check for poor plug connections or pinched wires, two, I would format the HDD again, and three upload the latest firmware no matter what version is on the machine now.
          • copierpro
            • Apr 2007
            • 270
            thanks for the help. I know all is straight under the control panel - I looked at all with a fine tooth comb before reseating paying particular attention to the connectors.
            Since I cannot get any action off the control panel I can't do another format as things are - unless there is is a power-up while holding a key(s) like Canon irs have and give that a try.
            Don't have the firmware but got a dealer 4 blocks from here for KM. Guess I'll pay them to come over and do the update. Just the system update good enough or do engine, too?
              • 22997
              The firmware is all inclusive. =^..^=
              • kkendric
                • 301
                Hey Blackcat don't you wish that you were so good that you never had to recheck your work? I wish I never had to.
                • copierpro
                  • Apr 2007
                  • 270
                  I rechecked it. That's why I had it off to begin with.
                  In any event up and running bad HDD. Thanks for all your help.
                    • 22997
                    If you've read any of my posts, you'd know that I screw up as many as I fix. The only thing I can refer to as an advantage is my mindless, stupid, hard headed, persistence. If not for that, I'd have no talent at all. =^..^=
                    • Jules Winfield
                      • Jul 2009
                      • 821
                      Just the fact that you take machines apart and at least look for a problem puts you ahead of the curve compared to a lot of techs...
                      But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
