I'm trying to identify the color release motor in the parts list for the 300ci. I'm not having any luck finding it. All help is appreciated. Thanks in advance.
Kyocera TASKalpha 300ci Color Release Motor
Re: Kyocera TASKalpha 300ci Color Release Motor
You will not find the motor nor can you order just the motor. It is inside the transfer belt. If you are getting the color release motor error change out the transfer belt."In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
When it was more common, I would scavenge these parts from a transfer belt assembly that had reached life, and was replaced. These parts are not available separately. If you don't have a used unit to scavenge from you'll have to order the transfer belt assembly. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
