co64o{ Km8030 }
  • Franky Tan
    • Aug 2025
    co64o{ Km8030 }
    At 1st i face with auto feeder faulty whenever i placed original copy on feeder tray,its show reset document processer, but i use u244 to check all sensor and switch its ok.I replaced DP main pcb board ,the feeder still show reset document processer whenever i placed original copy and i use u906 its come out with system error co64o, i replaced engine board and hdd but still cannot settle the problem.thank to all.
  • kwazimoto
    • Jan 2007
    • 199
    ISSUE DETAILS Related Models: KM-8030
    Issue Category: ERRATIC OPERATION
    Closed Date: 2006-05-24
    Print Page can not be combine showing reset. then code 0640. tried formatting no help. replaced HDD and formatted stopped with code 4579. then tried the main PCB and format came up with same code. bad HDD & bad paper feed deck pcb, replaced to resolve
    Close If you need to receive additional support for this issue, Be sure to include any additional information or questions that you may have. Also, please be sure to be as descriptive as possible.<H5>Please Click Here
    </H5>
    • Franky Tan
      c6o4o [km8030]
      [quote=kwazimoto;28100]
      Hello ! kwazimoto, when i click H5 i didn't see anything come out
      can u please send again. Thanks to
      u .if u can reply again. Because i need solution on Monday.I thinking to replace DIMM on main board u think is it posible to solve. Anything link with mainboard?how about Hv unit? i remember that i experieced falcon2 machine before co64o appear after i replaced dimm on main board the problem solved.
        • 23010
        I believe kwasimoto has suggested replacing the HDD and paper feed deck PWB as a set (concurrently).
        • Franky Tan
          I will try it tomorrow , keep u inform later. thanks.
          • Franky Tan
            My supervisor went down to repair the machine ,been told that HDD got three connector ,the center connector needed jumper which is forgotten by me.
