Cleaning Drum?or PROcess unit?
  • jewen25
    • Mar 2009
    • 194
    Hello i am thinking that there any solutioN or CHEmical that clean scratch drum?because i have a Opc thats been scratch by Staple wire?
    ERROR HELP ME AND HELP YOU
  • tonerleak
    • Mar 2012
    • 67
    Re: Cleaning Drum?or PROcess unit?
    I think you are looking at a new drum. Used to be able to polish selenium drums with limited success but have never seen or heard of an OPC being repaired.
    • 10871087
      • Jan 2005
      • 1143
      You can't fix that but you in luck, OPC drums are cheap.
      • jewen25
        • Mar 2009
        • 194
        how about the original drum? It can be clean?
          • 22929
          So you'd like to clean what exactly? Clean away the missing drum coating? It's too late. The drum coating is gone, and not readily replaceable, short of installing a new drum. =^..^=
          • ZOOTECH
            Senior member of CRS
            • 3374
            If the scratch is small enough, you could try a bit of nail polish - it won't transfer the image and you may have a repeating mark on your copies/prints (if the customer doesn't mind).
            Otherwise, the OPCs are cheap enough as mentioned.
