4050 not fusing properly
  • Tonerkiller
    • Oct 2012
    • 668
    I am going to look at this machine monday, one of my techs replaced the eng. board. A couple of days later the customer called and said that now the machine is only fusing in the middle. We put a fuser in the machine with no change. Has any one seen this problem?
  • JustManuals
    • Jan 2006
    • 9838
    Re: 4050 not fusing properly
    Paul@justmanuals.com
      • 23008
      What kind of media?
      What media settings?
      How many clicks on the existing fuser?
      What fuser heat settings are on the machine?
      OEM or aftermarket toner?
      • CWP
        • Jun 2013
        • 168
        Make sure both heater lamps are coming on. If they are not, most likely a connection, engine pwb or power source pwb, but since the engine pwb was just replaced before this problem was reported, my guess would be engine pwb or connection to it. (Or is that why the engine pwb was replaced in the first place?)
        • Tonerkiller
          • Oct 2012
          • 668
          The eng board was replaced because the drawer lift motor took it out. I had this same issue with a 250ci. I resolved that by doing a web page reset. I was not sure this model had that. I will post result.
          • Tebow83
            • May 2009
            • 92
            Was it fusing ok before main board was changed?
            I'd be looking at firmware first if its not up to date and then try a different power supply board. That failing I'd be trying the engine board.
            • Tonerkiller
              • Oct 2012
              • 668
              Yea it needs the base convaying, eng board and pm kit so I brought it in the shop. I will post the out come. The eng board is back orered,
