A 2550ci in the field is squeaking "lightly" but loud enough to aggrevate the staff. It's coming from the fuser section as it continues to turn after copying/printing. Any suggestions for grease types or other work arounds for this issue? I've been careful not to use the wrong type of grease/lubricants on these new fuser sections.
2550ci fuser "squeak"
Re: 2550ci fuser "squeak"
go to system menu
adjustment/maintainence
silent mode
ON
and you can try lubing the fuser bushing/bearings with hi temp greaseTesting 1-2-3, testing, testing. Is this thing on? -
are you sure its from the fuser? i had an annoying squeak coming from the fuser drive section. i pulled it apart and there was a nylon washer that was grooved by a spring. i flipped it around hit it with some grease and the sound has not returned.Comment
