DP-410 on a KM-2550 stopping.
  • Jimbo1
    • Mar 2008
    • 845
    We have a DP-410 that's on a KM-2550 that will stop feeding during a job for no apparent reason. I will have to find out for sure what the jam code that gts posted is but I was told it was not a DP code.
    They have swapped the feeder and have it here in the shop where of course it works perfectly andthe one that replaces it works perfectly.
    They did this before and all was lollypops till they took the feeder back out and it started up again.
    Grounding to the feeder has been confirmed. The harness and boards in between have been swapped.
    Any body got any ideas???
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • 30421
    feeder
    any codes?
    also new hinge from kyocera on a Q&A that grounds the feeder better
      • 23010
      This is just secondhand, but I remember hearing something about a new style DP controller board to address jamming. There is some sort of a grounding issue.
      I'm not the kind to start putting in main boards for no good reason, but if the part # is incremented upward 1 or 2 digits I'd give it a try.
      • Jimbo1
        • Mar 2008
        • 845
        We already have the grounding fix in there.
        Cdr. William Riker
        • flimmer
          • Jun 2008
          • 30
          Try opening the top cover - and then try to puch the take up roller up and down - if the 2 arms locks in the grove - place a mylar in the 2 groves - to make the arms go smoothly.
          • Fangers
            Try jiggling the loom that connects the DP-410 to the copier while copying and see if your problem re-occurs. Those looms cause intermittent faults.
            • gpoffmachs
              techie
              • Feb 2005
              • 55
              techie
              they replaced the boards for a new version for jamming, internal grou7nding failures
              Techie
              • 10871087
                • Jan 2005
                • 1062
                It is probably a grounding issue, there is a new tech bulletin out on it from KMA .
                • Jimbo1
                  • Mar 2008
                  • 845
                  We have verified it's not the grounding. however it's only doing it at one location. Bring it to the shop and it's a good boy.
                  Cdr. William Riker
                  • brasilmichaele
                    • Jul 2008
                    • 31
                    I got a tech bulliten from Kyocera that showed to run a ground between the feed in motor and the main motor. i just get a big paper clip and run it between the motors.
                    i think the problem is when you are running multiple originals in the dp there is alot of static build up that confusses the main logic pwb of the dp. i have also seen the hookup cord have issues also.
