Close cover error
  • edgarciarod
    Close cover error
    Hi everyone, I have a kyocera km-3530 everything was ok whit it until I
    opened the front cover for to clean the residual deposit of the toner, then
    I put it into its place and finally I closed the cover, everything like I always
    do it, but the message in the screen saying "close the cover" never disappeared.
    I don't know what to do .
    I hope that someone there knows what is happening. Thanks in advance.
  • Eric1968
    • 2458
    Re: Close cover error
    Broken door switch?
    • edgarciarod
      Originally posted by Eric1968
      Broken door switch?
      Do you know where can I find it?
      Seems like there is one sensor but I don't know if it is wrong or right .
      • MR Bill
        • 532
        Take the right front cover off of the machine and you will see the switch . Remove switch a take it to a electronic store and they can match it up. Are you a tech.? Call one of your venders?
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
            • 23010
            First thing to do is to find out which cover switch is giving you trouble. There are at least four switches that can give you "Close Cover" indications. Check each switch to find out which one is not being made (document processor, left upper door, left lower door, and front door). On this model the metal lever on the microswitches can get bent. That's a good place to start. =^..^=
            • MR Bill
              • 532
              End user blackcat , I gave the simple answer and anything more that that will need a tech.
