cs-2550 light prints
  • ROBIN JENTZEN
    • Mar 2010
    • 12
    [CQ] cs-2550 light prints
    have done all the cleaning of the mirrors changed out toner motor changed out both boards and even the dev. unit
    can run dev install and will work for a couple of day and then it will come back to light streaks pull the dev unit out and it looks as though there is no toner on mag where streaks are
    this is when you run prints wish does not use the mirrors, run Statius page and there is streaks run dev install and looks great
    what gives?
  • MR Bill
    • 532
    Re: cs-2550 light prints
    Not sure what gives. But when you pull out the dev unit and drum unit reach in that area of the machine and clean the window for laser. ? Worth a try. The mag roller looks like there is no toner on it but most of those machines look like that.
