CS 205c blank copies from Doc feed
  • jockey
    • Aug 2008
    • 52
    I have a CS 205c that had the "Black Image problem" that has been addressed in one of the tech bulletins and called for the main board to be replaced. The original problem was black image when making copies from the glass or the DF, no problem when sending print jobs they printed fine. I replaced the main board ran simm 04, now copies from the glass is fine but copies from the DF are blank image no image at all, went back and reseated cables on the main board with no luck, any Ideas anyone?
    • 22999
    Re: CS 205c blank copies from Doc feed
    When you pulled out the machine ... perchance did you accidentally engage the scanner lock so that the light source #1 can no longer reach the slit glass? =^..^=
    • kkendric
      • 301
      Tried to figure out same problem once, spent about 30 minutes before I realized that I had bumped the lock lever.
        • 22999
        It was just luck that a few days earlier I had read a post by a person who had come across the same thing. I couldn't remember the whole post, but I knew where to look for it.
        It took longer to boot up my laptop than to fix the problem. Thanks Copytechnet. =^..^=
        • Zackuth
          • Aug 2009
          • 448
          Yep, been there, done that. Pull out the scanner lock.
          If at first you don't succeed, redefine success
          • jockey
            • Aug 2008
            • 52
            Well add me to that list! that's what it was went back this morning and found the scanner lock was half way in. Thanks guys
              • 22999
              Congratulations. =^..^=
