Job accounting reverting back to default
  • snam
    • Aug 2025
    Hi everyone,
    I'm an IT admin for a small office (30+ people). We have two Kyocera CS 3050ci copiers. They are connected to one of our servers and then shared for users to connect through the server, ex: //servername/printer1.
    The Job Accounting is set up for a 5 digit Account ID that users input to print from these devices. The problem we run into is that this setting periodically goes back to a default state of not asking for the account ID. Users then are unable to print.
    Is this a driver issue? Network issue? We are running on Windows Server 2003. I am able to provide whatever information that you guys might need.
    Thank you for taking the time to read and look forward to your responses.
    Sam
    • 23009
    Re: Job accounting reverting back to default
    Do you have a setting to turn off SNMP?
    Alternatively, look in the Device Settings tab of the print driver. There will be a menu of AutoConfigure settings. Turn Off Silent Auto Configure, and select the appropriate options from the checklist. =^..^=
    • snam
      SNMP is set to SNMP v1/v2c with read and write community names as "public."
      I'm trying to look for this Silent AutoConfigure setting. I see Administrator, User, PDL and Compatibility buttons under Device Settings.
      • Geo
        • 662
        Hi Blackcat.
        What issues/problems are you experiencing with Autoconfig on?
        Is this for all versions of the print driver?
        • snam
          Originally posted by Geo
          Hi Blackcat.
          All I see on the Device Settings page are the buttons I mentioned above and AutoConfigure but that is also a button (not something I can turn on or off.) Poked around but didn't see what you were talking about blackcat.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            I have seen similar issues, try installing drivers locally to see if problem corrects
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • 23009
              With certain versions of the driver, I've seen configuration defaults lost (finishers, document feeders, paper decks, and memory upgrades disappearing from the configuration of the driver). The current theory is that Silent Auto Configure attempted to configure while the MFP was unreachable. The first time I came across it, I installed an older version of the driver that did not contain the Silent Auto Configure feature (which worked). On the second occasion I browsed around the driver until I found a way to disable the Silent Auto Configure feature. Again, I was successful (at least I did not hear of a re-occurrence). If I remember correctly, when you click Auto Configure on the newer versions of the driver you get three menu options, but I do not remember what they are.
              The bit about SNMP I picked up from posts here, but have not tried. =^..^=
              • JR2ALTA
                • Feb 2010
                • 2033
                SNMP is in properties-ports-configure port. uncheck it
                the theory is the driver periodically talks to the machine through SMNP protocol and if the machine is sleeping or off, or a miscommunication happens the driver gets messed up and sometimes can't recover.
                but there are more qualified techs to give you a better explanation, and of course, it may not even be the issue at hand.
                • snam
                  Thanks for all the responses. I will look into the printer auto config issue.
                  • tech.gasm
                    • Sep 2010
                    • 39
                    My queries are:
                    >>are u the only one with admin level access to the print server?
                    >>are the correct print drivers installed?
                    >> how about enabling the password feature on the device settings tab.
